Hi All,
I have found multiple scripts to copy drafting views from 1 file to the current document, but, I need the reverse of this. I have a master file and need to make sure that a change to this is updated across all files within a set directory.
Ideally the script will function as follows:
- select the directory to update
- select the drafting view to copy
If the view name already exists in the new file I would like it to override (so if placed on a sheet, it will remain).
I have gotten this far and know that the issue I am having lays with the rhythm node “Documents.CopyDraftingViewsFromDocument”. I was hoping that someone knew of a node that is the opposite to this?
