Hi, is there a way to convert gps (wgs84) points to state local coordinates and then load the point to the CAD plan using Dynamo?
You can use The Civil Nodes in C3D 2025, or the Arkance Systems Node Library in older C3D versions.
The node you need is called WGSPoint.
Thank you Anton. i found the node. works pretty well.
