Convert to project units
I want to move a view on a sheet by a specific mm value.
I want this to work no matter what the project units are.
I got it working by getting the project units and searching for the unit name, then filter different values by bool mask.
I just wanted to know if there is any better way to do this!? Happy about any thoughts!
just wanted to ask again if someone has a better solution to my problem.
I want to move a view by 20mm, it should work whatever the project units are.
Maybe there is a better and faster solution possible with python?
Kind regards
Yes, there is a better way available in the Revit API. There is a class called UnitUtils, which takes care of converting some units into another.
https://www.revitapidocs.com/2020.1/cad8b885-8eda-5556-4813-924b7a7e669b.htm
Your current Unit System should be the Millimeters and the desired should be the project units
Thanks @Joelmick :slight_smile:
I did a little search for unitutils, i found a few nodes and tried to put something together, but it does not do what i want it to and i don´t even know what its doing exactly :smiley:
What is this result i get with UnitUtils.Format?
I think it is not what i need because as you mentioned i have to convert to project units.
Edit:
And thats my try at converting to project units:
But don´t know how to put this all together and get correct results.
I started to put a python script together, but again, i don´t really know what i´m even doing.
getDocUnits = doc.GetUnits()
getDisplayUnits = getDocUnits.GetFormatOptions(UnitType.UT_Length).DisplayUnits
unitConversion = UnitUtils.ConvertFromInternalUnits(1, getDisplayUnits )
OUT = unitConversion
Hi @gerhard.p,
The Python solution you are now using is to convert back and forth between Revit’s internal units (Feet, dont ask me why feet)
You should use the Convert methode:
#Import the Revit API
clr.AddReference("RevitAPI")
#Import the Revit Services
app = uiapp.Application
#Take a number an converts it from mm to Project Units
def ConvertUnits(num):
	unitType = UnitType.UT_Length
	currentDisplayUnits = doc.GetUnits().GetFormatOptions(unitType).DisplayUnits
	return UnitUtils.Convert(float(num), DisplayUnitType.DUT_MILLIMETERS, currentDisplayUnits)
OUT = ConvertUnits(IN[0])
@Joelmick saved the day :smiley:
Thank you so much it works great, my script is now cleaned up, nice :slight_smile:
So this method does not work for Revit 2022 because the Unit Methods have changed.
I changed the code an it seems to work :slight_smile: heres a comparison of the code lines:
#Revit 2022
unitType = SpecTypeId.Length
currentDisplayUnits = doc.GetUnits().GetFormatOptions(unitType).GetUnitTypeId()
return UnitUtils.Convert(float(num), UnitTypeId.Millimeters, currentDisplayUnits)
#Revit 2021
And here is the full code for Revit 2022:
