I closed the other topic since it is so old .
The reason for this is that the imported mesh is of the MeshToolkit type. If you want to translate it to a polysurface I strongly advice you to check out the spring nodes package. It has a ToolkitMeshToMesh that you can use. Then you can utilize the Mesh.ToPolysurface node from the very same package.
Thank you so much!
