I am experiencing a problem with Civil3D 2024 where “ꟿ Mesh.ToTkMesh” is not working.
The program is trying to convert a selected Surface in Civil3D into a Mesh that can be used in Dynamo.
The Spring node ꟿ Mesh.ToTkMesh in it returns null.
How can I solve this problem? I would appreciate your help.
Here is the version information I am using.
・Civil3D 2024.3 Update
・Dynamo v.2.19.4
・Spring node 210.1.1
Not sure but when I read about Spring nodes package it say that it is for Revit API so that could be the reason.
That node should be pure Python/Dynamo core.
The issue is with the mesh toolkit package being unsupported in this build. @s.iwasaki uodate to a later build of mesh toolkit (but not one for Dynamo 3.0), or move to an alternative workflow.
@patrick.ericson @jacob.small
Thanks for the reply.
So it worked in Civil3D 2023 but is not supported in Civil3D 2024?
Also, I would like to use a surface created in Civil3D as a PolySurface in Dynamo. Is there any way to do this?
Thank you in advance.
Maybe not the best way to get polysurface from surface but it’s one way
Thank you for your reply.
I was able to create a PolySurface using the method you taught me.
It took a lot of time to create the Surfaces because there are so many Surfaces to combine in my program.
