Hi all!
I am trying to convert dynamo curves to revit modelcurves. I thought converting them using ToRevitType() would do the job but it only creates a Revit.DB.Line and doesn’t create the modelcurves as desired.
Do I need to create the ModelCurves using the Document.Create.ModelCurve or is there another quick conversion method?
Yes - you need to convert the curve to a model curve using the method you referenced.
ToRevitType() is just a geometry conversion. In order to create an actual element you would need to use Document.Create.ModelCurve if using the API and Revit geometry or ModelCurve.ByCurve if using Dynamo geometry and nodes.
Thanks for the response Nick!
For some reason, originally, when I used the node ModelCurve.ByCurve it didn’t work noting that it works only in family document (or something of the sort) but now that I have closed the dynamo and reopened it it works…
Sounds like you grabbed a similar (maybe custom) node meant for family editing and not the standard one.
