Set "Identity Data", "Is Reference Line" as true
Hi everyone,
I would like to convert a “model line” into a “reference line” inside Revit.
Is there a way to do it trough a dynamo script, otherwise accessing the Revit API?
Does anyone know some method to solve this issue?
Thank you
Here’s the API method: ConvertModelToDetailCurves Method
If you want to skip python you’ll likely have to get the curve geometry from the ModelCurve and use that to create a DetailCurve. Then you can just delete the old ModelCurve.
