Hello everyone,
which node converts a DirectShape into a room or MEP room?
Best regards
Rolf
Hello everyone,
Best regards
Rolf
Hi Rolf,
You could get a point on a DirectShape and use that to place a room? (âMEP roomsâ are Spaces)
Hopefully that helps
Mark
Hi Mark,
can any point on the space boundary be used, including a corner point, or does the point have to be in space?
Best regards
Rolf
Hi Rolf,
It would want to be inside, so Iâd probably get the average point? You might be able to get the bounding box of the Directshape which would compute faster? It wouldnât matter that the bounding box is axis aligned for the purpose of the centroidâŚ
Hope that helps,
Mark
Hi Mark,
thanks for the help.
Unfortunately, in L- or U-shaped rooms, the center of gravity may also be outside the room contour.
Is there maybe another method?
Best regards
Rolf
Hi Simon,
Thanks for the link. There is âSearchâ, but âFindingâ is sometimes difficult!
So far I have used: Move the room outline inwards by 0.5 meters and use the center of an offset outline line with Space.ByPoint.
Iâm testing which solution runs faster.
Best regards
Rolf
