Convert cad to revit 3d
Could u please share with me dynamo script to conveet Autocad mechanical works to revit 3d if someone did it before because I’m still beginner thanks.
Hello @hopemib3 and welcome i would really like to do that, but you will need show your exackly situation, when we talk cad to 3d revit many things can go wrong depends the situation…so please show us first what you have tried so in dynamo, perhaps share the cad file here…and we all here would be clever
Welcome to the forum @hopemib3.
Please have a review of the community guidelines, as well as the following post: How to get help on the Dynamo forums - FAQ - Dynamo.
Specifically look at item 7:
You might get some assistant here with the generic “help”, but you’ll get far better support with relevant files to recreate, or even better still an attempt at a graph which gets most of the way there. As of now you’re asking those who want ot hlep you to:
  1. Build a dataset in AutoCAD of mechanical works. The quality of your CAD data won’t match what I would build as an example, and only you know the standards you’re building to.
    • We don’t need real project data, but a sample dwg with 3-5 items to convert.
  2. Build a relevant Revit model to convert the data into. Your Revit template won’t likely match what I’d pick - offhand I’d go with ‘None’ as my template using Revit 2027, but you might be in Revit 2024 using the Mechanical and Plumbing template.
    • Dosen’t need to be your full rte, but enough to match the relevant info you want to port over.
  3. A Dynamo graph that converts the data. All the nodes, using whatever means we want, executing in our environment which you might be blocked from using (i.e. I won’t run anything requiring an IronPython engine, but will happily use many zero touch based packages that you might be blocked form installing).
    • Again knowing what your limits are will help a lot here, and a sample graph of what you’ve got so far is a good way to build this information.
If any of the work in steps 1 or 2 doesn’t align to your work then step 3 might not work at all. And in the absence of samples or the written restrictions your working with there’s a high likelihood step 3 won’t work even if steps 1 and 2 are perfect.
So… feel free to attach a dwg, rvt, and any dyn of work so far that could help others identify what you’re after. I’m bumping your trust level to allow for such now so it should be possible in about 5 minutes.
