I was trying to use @T_Pover’s Element.ConnectInto Node to connect pipes to a VAV box, but it did not work at all. I have only selected one pipe and one VAV element.
The VAV box is a custom family but the sprinkler is “M-Sprinkler-Horizontal Sidewall-Fully Recessed -Hosted 15mm Horizontal Sidewall” and the pipe is “Domestic Water-Copper”
The sprinkler and pipe worked with ConnectInto. I’m guessing the VAV box doesn’t work because it has multiple connectors and you can’t select which connector to connect the pipe to. I’m thinking of using the MEP Connector Info node to get the connector and using that and the pipe in the Element.ConnectInto node. Does this node work for connectors as well?
I have not, but depending on the situation there might be another workaround. I do think it would be best to start a new topic explaining your problem in that case.
