I have successfully created the flex pipes using this node (Refer image)
But the issue is, if i move the connector, the flex pipe stays in the original position. My aim is that the flex pipe has to move if i move the connector.
Please suggest me a solution or any particular node for this
Hi not sure i 100 understand, but sounds for me the flex isnt real connected from the start
yes, i have two connectors or either end, and using dynamo i extract the coordinates of the connector and modelled the flex pipe. But when i move the connectors, the flex pipe is not moving.
I need the flex pipe to be moved along with the connectors
yes these are not connected and as you will see if you go to analyze and set show disconnected option to on…
yes, then how can i make pipe connected to the connectors.
is there any particular node for that?
you could try connect mep curves from genius loci
i’ve tried your solution but it returned as null. May i know what you given as list 2 apart from flex pipes?
yeah it was just these 2 ducts i select for create flex in my example…gives null ? which revit version are you in ? be sure you have the right ironpython installed
Revit 2024.3, Dynamo 2.19.3, Ironpython 2.5
if you share that family and your dyn, i can take a look later or tommorrow if you isnt have find a solution
