Connecting pipes together failing
hello,
i’m trying to connect sprinkler branch pipes to the main pipes with no luck.
05. Pipe Creation and Connections REV1.dyn (91.2 KB)
can anyone help detect the problem.
Hi @sahawneh_majdi think if you share a rvt sample file as well, you will have better luck with help…
hello,
apologies, coudn’t upload the file here, however, it is very simple as shown in below snips, distributed sprinklers and the script create branch pipes out of sprinklers and at an offset, it creates the main pipe.
snip 1- before the script run:
snip 2 - after the script run:
You cant upload the file here?
Strip the file down to 17 sprinklers in a room and send that?
