I’m working on a tunnel project and trying to generate the water deluge pipe along the control line. The thing is I generated all the pipes successfully but failed to connect them with the node MEPFitting.ByMEPCurves
I believe the problem is the angle between these 2 pipes is too tiny, but isn’t it very normal in a linear MEP design? Is there anyone have a idea about this? Thank you so much!
