i have created a script to place and connect a fabrication part over another fabrication. script throwing an error message as can see in the image. My script is also below. anybody can help me to identify the error in the script?
duct offset.dyn (54.1 KB)
# Enable Python support and load DesignScript library
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
import math
from Autodesk.Revit.DB import FabricationService
app = uiapp.Application
levelid = doc.ActiveView.GenLevel.Id
servicebutton = IN[0]
length = IN[1]
host = UnwrapElement(IN[2])
fabricationpart = FabricationPart.Create(doc, servicebutton, 0 , levelid)
def dtor(value):
r = UnitUtils.Convert(value, DisplayUnitType.DUT_DEGREES_AND_MINUTES, DisplayUnitType.DUT_RADIANS)
return r
def GetPrimaryConnector(el):
cm = el.ConnectorManager
for i in cm.Connectors:
info = i.GetMEPConnectorInfo()
if (info.IsPrimary):
return i
def GetSecondaryConnector(el):
if (info.IsSecondary):
return i
lengthoption = fabricationpart.LookupParameter("Length Option")
lengthoption.Set("Value")
lengthParam = fabricationpart.LookupParameter("Length")
lengthParam.Set(length)
doc.Regenerate()
pc = GetPrimaryConnector(fabricationpart)
sc = GetSecondaryConnector(fabricationpart)
host_pc = GetPrimaryConnector(host)
host_sc = GetSecondaryConnector(host)
if host_sc.Shape == ConnectorProfileType.Rectangular:
pc.Height = host_sc.Height
pc.Width = host_sc.Width
pass
doc.Regenerate()
FabricationPart.AlignPartByConnectors(doc, pc, host_sc, dtor(0))
doc.Regenerate()
FabricationPart.ConnectAndCouple(doc, sc, host_sc)
doc.Regenerate()
OUT = 0
