Python Attribute Error
Hi All,
The bellow code I used some days before.It was working fine.
@T_Pover Wrote this for me.But Its not working now.
fittings = UnwrapElement(IN[0])
refs =
for x in fittings:
connset = x.MEPModel.ConnectorManager.Connectors
conn_pipes =
for c in connset:
if c.IsConnected:
for lc in c.AllRefs:
conn_pipes.append(lc.Owner)
refs.append(conn_pipes)
OUT = refs
It looks like the input is not a pipe fitting or maybe it’s nothing at all. Can you put a watch node between the nodes to see what’s going into the python node or share your .rvt + .dyn file.
Revit File
B.dyn (2.8 KB)
@bikashseas Looks good to me. Restart your PC and see if that helps.
Yeah, same here, works fine.
Yes ,Its working…
Thanks All.:slight_smile:
