Please advise.
not sure i cant then…share you cad example here…it could be good…but again play with it
cad lins.dwg (49.4 KB)
Hi works fine here exept one , as you have fitting to close, overlap…
for T fitting use this one here instead…seems more stable (thanks to Cyril)
t fitting.dyn (5.8 KB)
still struggling
I bypassed the “Rectangle Marked” node and used the “Elbow” node instead, which resolved the issue but still issue in the junction point.
Still not running same script at my end.
Try do exackly what showed…ps now it seems you have change revit version,my example is for 24, and for T use that node i post
I have just cross-checked in Revit 2022.
T junction.dyn (51.8 KB)
yeah will love to help you ;)…i will first be in dyn tomorrow, but for now share sreenshot with all nodes pinned so we can see whats go trough…and probably someone have a solution for you
I am very grateful to you for helping me in every possible way to move forward.
Any update?
you will need show you graph, with all nodes bubbles open so we can see where its go wrong
still works here…but you dont have set your does intersect node to crossproduct…
T junction.dyn (53.2 KB)
and if it still fail for you, check you have dynamoironpython package 2.7 ver 2.5 if you are in 23-24…for mepover node
