Dear All,
Apologies if this topic exists but searched and could not find what I was looking for.
Within my Revit model I have an instance based parameter which has been populated for all elements. I then have an Excel referencing document. The Revit models instance parameter has been populated manually by a previous user from Column A of the Excel document.
I need to create a script to read the Excel referencing document and where it recognises matching values between Revit and Excel - Column A, to populate another instance parameter for the same element with the contents of Column E.
As you can see from the screenshot, I am a Dynamo beginner. I can read the Excel but what function do I need to align the parameter values with list 0 and populate the Set.Parameter with matching list 5 values?
Many Thanks,
Lee
