The short question is:
How can use a value from one multiline text parameter, and combine it with values of other multiline text parameters?
This is the long explanation: I use Engipedia Layers Manager addon that transforms the structure of elements into a multiline text parameters. For example,
Floor 001 has a multiline text parameter “EN Layers and Widths” that has a value:
Ceramic Tile 1cm,
Cement Screed 5cm
Just bellow Floor 001, we have another floor. Floor 002 has a multiline text parameter “EN Layers and Widths” that has a value:
Concrete Slab 20cm
Bellow concrete slab we have a suspended ceiling. Ceiling 001 has a multiline text parameter “EN Layers and Widths” that has a value:
Air,
Substructure 4cm,
Gypsum board 1.25cm,
Skim Coat and Paint 0cm
Floor 001 will be hosting a component. With the help of dynamo, this component will detect all elements bellow (in this example, two floor elements, and the ceiling). I have no problem to use clash detection, but I don’t know how to combine the parameters afterward. I need to populate the multiline text parameter of the component that is hosted to the top floor. The parameter named “Assembly 1” should have this final value:
Ceramic Tile 1cm,
Cement Screed 5cm,
Concrete Slab 20cm,
Air,
Substructure 4cm,
The reason being are building codes in my country. We can’t tag elements individually, we need to have a mark for the whole assembly instead. However, it makes no sense to create Revit assemblies for all floors, ceilings, roofs, and walls. Therefore, I want to use a component and place it wherever I need a tag. This component will detect all elements, describe them and assign unique marks to itself. It will be schedulable. The schedule of the component will describe all layers used in the project. It will be used for calculating building efficiency.
I just need help with combining multiline text parameters. Lets say I have three lists of multiline text parameter values.
List A has two items with values
Layer a1,
Layer a2
Layer b1
Layer b2
List B has two items with values:
Layer a3,
Layer a4
Layer b3
Layer b4
List C has two items with values:
Layer a5
Layer b5
I need a list D that has these two items as final result:
Layer a1,
Layer a2,
Layer a3,
Layer a4,
Layer a5
Layer b1
Layer b2,
Layer b3,
Layer b4,
Layer b5
Big thanks for your help.
