I’m using Dynamo to create a list of equipment that is in excel but not in Revit, and in Revit but not excel. I’m wondering if there’s a way to colour in the equipment in Revit, so it’s easier to visualize what hasn’t been done. At the moment I’m outputting a list of equipment that is yet to be named in Revit, however this list is just a string.
Sure. Find the index of the item in the list and use Get Item at Index. Or find a way to get a list of true/false (IsEmpty should work) and use Filter by BoolMask.
@Greg_McDowell the “IsEmpty” only returns if the whole list is empty, and I don’t want to manually type in index 7 for “GetItemAtIndex”. Even if I could check for a specific index if it’s empty, it still contains {} in the string
@Greg_McDowell didn’t know about that trick. However at index 7 it still contains {}, so it’s not empty. And if I convert it all to a string and remove {} from it, then it gets rid of the indexes
@Greg_McDowell yeah just put in == and a string block of nothing. But I’m still not sure how to get all elements at index with a value of true, and then apply the colour to them
