Color Reset For Air Terminals
I was wondering if it would be possible to reset the color back after I run this. I was thinking it would go back if my CFM was lower than the max.
Hi @mikebAPVMK,
You can use one the View ResetElementOverrides nodes.
Basically you just want to start with your script clearing out any previous overrides and then reapplying them as needed. So every run is current.
How would i go about doing that?
Please make an attempt before asking for help. You already have a script that can apply overrides based on a condition. Start off with similar logic to clear all overrides (using the nodes mentioned by @Alban_de_Chasteigner or others) and then check your condition.
Thank You Both
