Hello
I am an office worker studying dynamo in Korea. I’d like to put room information in the mass and the same information in the mass objects (pipe, fitting). For example, if you have a property called Mass-A, you want to put the same property as PIPE-A. If you use a bounding box, but not a square, objects in other mass, other than the selected mass, also change their attributes. Is there a way?
Hi @and.kj.cho,
Welcome to the forum. To get a fast answer, please show everything in your graph.
What is the error the last nodes gives you?
What are you putting in the Node, Which Element, Which Parameter and Which Value?
Please provide this, so we can help you more accuratly
