Collect View Names from Linked Model
How do i get the View Names from a Linked Model?
I have a code that duplicates view that’s working perfectly from a non-linked model but i want to apply the same to a linked file.
I’m getting dereferencing to a non-pointer.
Hey,
I would guess that you’re also getting view templates and they don’t return a value for ‘View Name’ try Element.Name instead…
Hope that helps,
Mark
I’m trying to get the views from a linked model, not on the current document
Here is a possible way :
view%20names
@Alban_de_Chasteigner Nice node! Yeah the issue is that calling ‘View Name’ parameter gives empty values, whether or not it is a link…
@Alban_de_Chasteigner thank you so much!.
do you happen to have something for the sheets as well?
i want to copy sheets + Views from a linked file…
Simply connect the Sheet output to the View Properties node.
Use a List.Join node for the views+sheets.
Thank you so much!
