Collect callouts
in my list there are 2 of them @vanman ! i set the second one!
2022-05-11_12h07_53
both dont work for me unfortunately
did you check regular stuff f.e. @vanman
1.) are you still in a work mode
2.) selected something during running
3.) restart dynamo
anyone know how to use GeniousLoci method to input a link doc with the get all callouts code?
#Part of script from Clockwork
inputdoc = UnwrapElement(IN[0])
if inputdoc == None:
elif isinstance (inputdoc, RevitLinkInstance) :
	doc = inputdoc.GetLinkDocument()
elif isinstance (inputdoc, Document) :
	doc = inputdoc
else: doc = None
restarted dynamo, had both View Reference nodes going, empty
holy shit just pasting it in got from links too. Ideally just want to get references from views though…
#Alban de Chasteigner 2018
#twitter : @geniusloci_bim
#geniusloci.bim@gmail.com
# Import RevitAPI
clr.AddReference("RevitAPI")
	doc = inputdoc
else: doc = None
collectorViewer = FilteredElementCollector(doc)
OSTviewers = collectorViewer.OfCategory(BuiltInCategory.OST_Viewers).ToElements()
def GetAllCallouts(_doc, _OSTviewers):
	CalloutParent = []
	for view in _OSTviewers:
		paraIndex = BuiltInParameter.SECTION_PARENT_VIEW_NAME
		parameter = view.get_Parameter(paraIndex)
		if parameter != None:
			element = _doc.GetElement(view.get_Parameter
			(paraIndex).AsElementId())
			if element!= None:
				CalloutParent.append(view)
	return CalloutParent
OUT = GetAllCallouts(doc,OSTviewers)
How do you want it exactly?
A node that would get selected views callout references in the document/links. Fake and real references. Then I’m going to schedule the data from that and put it next to the view on a sheet to show where all references are for that detail
Like this?
# Import RevitAPI
view = UnwrapElement(IN[0])
CalloutParent = []
for v in view:
	parameter = v.get_Parameter(paraIndex)
		element = doc.GetElement(v.get_Parameter(paraIndex).AsElementId())
		if element!= None:
			CalloutParent.append(v)
OUT = CalloutParent
seems very promising but there should be 4 callout elements from this view. Sorry if I’m explaining incorrectly
Have no solution yet, what does this node?
just returns emptys
Hmm strange…
@Konrad_K_Sobon any thoughts?
Hello
I don’t know what kind of list structure you want in the end, but here’s an example
import System
# Import RevitAPI
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
def get_Sheet_Callouts(currDoc, v_callout):
	c_filter = ElementClassFilter(clr.GetClrType(DB.Viewport))
	lst_vpIds = v_callout.GetDependentElements(c_filter)
	for vpid in lst_vpIds:
		viewport = currDoc.GetElement(vpid)
		sheet = currDoc.GetElement(viewport.SheetId)
		if sheet is not None:
			return sheet
	return "'{}' not placed in a Sheet".format(v_callout.Name)
toList = lambda x : x if hasattr(x, '__iter__') else [x]
out = []
lstviews = toList(UnwrapElement(IN[0]))
for view in lstviews:
	if view is not None and not view.IsTemplate:
		currDoc = view.Document
		filterFunc = System.Func[DB.Element, System.Boolean](lambda x : currDoc.GetElement(x.GetTypeId()).ViewFamily == ViewFamily.Detail)
		enumIter_DetailCallout = FilteredElementCollector(currDoc, view.Id).OfCategory(BuiltInCategory.OST_Viewers).WhereElementIsNotElementType().Where(filterFunc)
		temp = []
		for v_callout in enumIter_DetailCallout:
			sheet = get_Sheet_Callouts(currDoc, v_callout)
			temp.append([v_callout.Name, sheet])
		if len(temp) > 0:
			out.append([view, temp])
OUT = out
You know what sorry guys. I haven’t looked at revit correctly. So I want what sheet each callout is on. Even though the callout is on a different sheet it only reports the one referencing sheet! How do I get the sheet of the element? Maybe get the view of the element then the sheet of the view?
this should have had the other referencing sheet in it
@Nick_Boyts if your interested
I might be out of luck getting the callouts sheets… Should be AA4011 in there too. Or I search every view on a sheet for a callout… Very slow collecting callouts from views on sheets :melting_face:
