Get Sheets From Document
Hi - I’m attempting to grab all sheets from a given document. I’ve used a clockwork node that collected all the views as the basis and just changed the class that is collected:
clr.AddReference('RevitAPI')
inputdoc = UnwrapElement(IN[1])
if inputdoc == None:
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.RevitLinkInstance":
	doc = inputdoc.GetLinkDocument()
elif inputdoc.GetType().ToString() == "Autodesk.Revit.DB.Document":
	doc = inputdoc
else: doc = None
collector = FilteredElementCollector(doc)
views = collector.OfClass(ViewSheet).ToElements()
viewlist = list()
for view in views:
	viewlist.append(view)
OUT = viewlist
Can you show the inputs for the python node? It is hard to tell what you are inputting and IN[0] isn’t even referenced in the script.
Sure - I’m trying to collect all views and sheets from the document to delete the ones I don’t need to issue. The python is copied from the clockwork node shown.
Can you show what the output of Application.OpenDocumentFile is? It might not be Autodesk.Revit.DB.Document, but Revit.Application.Document, which would throw up an error.
Turns out it was sending null - probably because I had been testing too many things and the file was still loaded in memory somewhere. It’s now working so all good.
