I am trying to translate the following code written in Rhinoscript to a single code block using DesignScript.
Option Explicit
Dim v
For v = 0 To Pi Step .01
SPHERE()
Next
Sub SPHERE()
Dim u
Dim x, y, z
Dim arrPoints
For u = 0 To 2 * Pi Step .01
x = 2 + sin(v) * cos(u)
y = 2 * sin(v) * sin(u)
z = cos(v)
If IsArray(arrPoints) Then
ReDim Preserve arrPoints ( UBound(arrPoints) +1)
Else
ReDim arrPoints(0)
End If
arrPoints(Ubound(arrPoints)) = Array(x, y, z)
Next
Rhino.AddCurve arrPoints
End Sub
Any help to translate the code is greatly appreciated!
At the moment, I am having issues with the for loop in the SPHERE() function definition. My attempt below
geometry = [Imperative]
u = 0.00;
v = 0.00;
x = 0.00;
y = 0.00;
z = 0.00;
arrPoints = {};
for (u in 0..Math.PiTimes2..0.01)
x = 2+Math.Sin(v) * Math.Cos(u);
y = Math.Sin(v) * Math.Sin(u);
z = Math.Cos(v);
arrPoints [u] = Point.ByCoordinates(x, y, z);
return = arrPoints;
To get the full circle, you’ll need to convert the radians to degrees because the Sine and Cosine nodes expect their input to be in degrees.
By the way, if you’re only after spherical coordinates, you could also use the Point.BySphericalCoordinates node and by changing the scaling of the coordinate system input (cs), modify the overall shape:
a = 0;
b = 0;
arrPoints = [];
for (v in 0..180..5)
for (u in 0..360..5)
x = 2 + Math.Sin(v) * Math.Cos(u);
z = Math.Cos(v);
arrPoints [a][b] = Point.ByCoordinates(x, y, z);
b = b + 1;
a = a + 1;
b = 0;
return List.Clean(NurbsCurve.ByPoints(arrPoints),false);
However, if I change the parameters to match the following
Option Explicit
Dim v, Pi
For v = 0 To 2 * Pi Step .02
SPHERE()
Next
Sub SPHERE()
Dim u
Dim x, y, z
Pi = 4 * Atn(1)
Dim arrPoints
For u = Pi / 2 To 3 * Pi / 2 Step .02
x = ((3 / 2) + sin(u + 2 * v)) * (cos(v) + cos(2 * v) / 10)
y = ((3 / 2) + sin(u + 2 * v)) * (sin(v) + sin(2 * v) / 10)
z = (sin(sin(cos(u + 2 * v) + cos(12 * u) / 12)))
Else
ReDim arrPoints(0)
End If
Next
End Sub
expecting this as a result
I come up with the following code
a = 0;
b = 0;
arrPoints = [];
for (v in 0..2*180..2)
for (u in (180/2)..(3*180/2)..2)
x = ((3/2) + Math.Sin(u+(2*v))) * (Math.Cos(v)+Math.Cos(2*v)/10);
y = ((3/2) + Math.Sin(u+(2*v))) * (Math.Sin(v)+Math.Sin(2*v)/10);
z = (Math.Sin(Math.Sin(Math.Cos(u+(2*v))+Math.Cos(12*u)/12)));
b = b + 1;
a = a + 1;
b = 0;
u = 180/2..3*180/2..2;
v = 0..180*2..2;
x = ((3/2) + Math.Sin(u + (2 * v)<1>)) * (Math.Cos(v) + Math.Cos(2 * v)/10);
y = ((3/2) + Math.Sin(u + (2 * v)<1>)) * (Math.Sin(v) + Math.Sin(2 * v)/10);
z = Math.Sin(Math.RadiansToDegrees(Math.Sin(Math.RadiansToDegrees(Math.Cos(u + (2 * v)<1>)<1> + (Math.Cos(12 * u) / 12)))));
s = GeometryColor.ByGeometryColor(NurbsSurface.ByPoints(Point.ByCoordinates(x,y,z)),Color.ByARGB(150,255,150,100));
Imperative
a = 0;
b = 0;
arrPoints = [];
z = (Math.Sin(Math.RadiansToDegrees(Math.RadiansToDegrees(Math.Sin(Math.Cos(u+(2*v))+Math.Cos(12*u)/12)))));
b = b + 1;
a = a + 1;
b = 0;
