I am having issue with the automatic creation of Revit sheets. The node I am using is Sheet.ByNameNumberTitleBlockAndView. My sheets are being numbered and named fine for the most part, but some views will wind up on the wrong sheets or in some cases a sheet will be made and the view wont be placed on it. Any ideas why?
I want to take my plumbing views and separate them out. My sanitary views are to be numbered starting with 200, water starting with 300, and so on. I use String.Contains and List.FilterByBoolMask to achieve this. I have been mostly successful with this. In the case where I want my plumbing roof plans views to be separated out, since there is also a roof plan under mechanical and electrical, I first filter by “plumbing” and then do another round with “roof”…is there a more efficient way? I there a way to just say to look for the views that contain both “plumbing” AND “roof” in one code block?
Is there a way to make my code more efficient in general? I have tried using a code block to write a for loop or a while loop but I am missing something or a few things on how to write the actual code properly. I’ve taken the node groups and just copied and pasted a bunch.
Below shows the craziness. Right now it is just looking at floor plans, but I want to also add drafting views to this. My first three nodes are ViewType which I selected floor plan in the drop down, which connects to Views.GetByType, which connects to Element.Name+ , which then connects to all the groups.
