I have a problem, I need to put the coatings in the environments. I created a routine to select all the environments, the type of covering and the height of the covering, but when I send it, Dynamo creates a covering in the middle of the environments. I’ll put a picture with the problem and the routine I created
I replicated it and it works fine. Differences in green.
My wall’s location line are set to, 'Wall Centreline"
Thank you very much, it worked perfectly
