Hi guys I am getting weird results when trying to find the closest point in the shorter list from the longer list. I shouldnt be getting the duplicate results like this. I tried multiple nodes with dubious results. See below. Does anyone know why this isnt working? Thanks in advance!
Hmm, without seeing the internal of the custom node (perhaps there is an issue with reading the correct index within) I can only offer another option.
Give this a try
import sys
# Inputs
short_list = IN[0]
long_list = IN[1]
# Output list
result = []
# Loop check for each point in the short list
for s in short_list:
# List for distances
dist = []
for l in long_list:
# Distance to point s
d = Geometry.DistanceTo(s,l)
dist.append(d)
# Lowest distance in list
min_d = min(dist)
# Index of lowest distance in list
min_ind = dist.index(min_d)
# Get the closest point from the long_list
closest_p = long_list[min_ind]
# Add the point to the results, as it is the closest to the point from the short list
result.append(closest_p)
# Output the results
OUT = result
