Hi All,
I just tried to get the areas of the different room faces through Clockwork’s Room.Finishes Node in R20 with Dynamo 2.1.0 and it wont work. I’m getting “nulls” in all different ways I tested. Anybody else got the same issue? Or am I missing something?
In R19 with Dynamo 2.0.3 the Node works perfectly…
Thanks in advance!
Open the node and do the following. Check if it still gives null value.
This way it’s working. Thanks!
Can you help me understand what’s going wrong during the use of the custom node?
If it helped, please select the solution
My best guess is that there’s somewhere error along the way in the part of the node where @Andreas_Dieckmann out putting the values of the area in the units of the view. Where exactly, I can’t really say, but would be handy if it will be fixed in the package update.
