Hello everyone !
I’m trying to get the hosted elements on my walls but i cant fine the elements.inserts nodes in the clockwork package i’m using dynamo 2.3.0 and the latest clockwork version ( for dynamo 2.3.0 )
Was this node deprecated ? if so is there a workaround to get the same result ?
Thanks in advance !
Is this one that you are looking for?
I just typed insert in the search tool.
I think we are using the same Dynamo version.
Try to follow this path:
Clockwork > Revit > Elements > Element > Inserts
Thank you @EdsonMatt and @sovitek ! Sorry for my late response ! But i can’t seem to fine neither of the nodes mentionned ! This is my dynamo version
The OOTB node doesn’t show in the search bar ! At this point i’m guessing it has to do with my dynamo version !
What happends when you type in something here…
I just get no results !
