Clear list of targets
I have created a script that adds a vast number of targets to specific subasseblies in all regions. The addig part works fine with the C3D Toolkit nodes but I’m stuck with deleting the target list before adding the new one. I try to clear the ObjectIDCollection, but dynamo says there is no such attribute.
What am I missing here? Thanks.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
tinfo = IN[0]
with adoc.LockDocument():
	with adoc.Database as db:
            # Place your code below
			x = tinfo.TargetIds
			x.Clear()
       	t.Commit()
The input object type is Autodesk.Civil.DynamoNodes.SubassemblyTargetInfo, so you’d have to have to get the underlying Autodesk.Civil.DatabaseServices.SubassemblyTargetInfo object via the transaction before any of the API members can be called.
Oh, okay thanks @zachri.jensen . That makes sense.
Although, I’m trying to get the Autodesk.Civil.DatabaseServices.SubassemblyTargetInfo object without success. I looked up some solution ideas on the forum, but none of them seem to work.
Tried InternalDBObject and InternalObjectID, but it says there are no such attributes.
I have also tried to figure it out from the toolkit dll, but I’m not qualified enough to understand the inheritance from there.
You can get the object ID using InternalObjectID and then get the object from that using Transaction.GetObject.
That is exactly what I was trying to do, but I guess I’m doing something wrong:
tinfo = IN[0]
			targetinfoId = tinfo.InternalObjectID
			targetinfo = t.GetObject(targetinfoId, OpenMode.ForWrite)
       	t.Commit()
        pass
OUT = targetinfo
Hi
I haven’t tried that
You can use the code on the page with the appropriate change
If that doesn’t work, can you attach an example of a dynamo file?
Sorry @kovacsv, I misread the steps you’ve taken so far. It looks like the SubassemblyTargetInfo class in the Toolkit doesn’t inherit from CivilObject (or ultimately ObjectBase), so that’s why the InternalObjectId property isn’t available. So I think your Python node will have to start with the Corridor as the input (since you can get its ObjectId) and then work your way down the class hierarchy to access the target info.
I was afraid I have to do that, sorting and list management may be a bit tricky for me in Python, thanks anyway.
