The node “CivilSurface.GetTrianglesSurfaces” gives the following warning (see fig. 1 and fig. 2).
"Get all the triangle surfaces in a CivilSurface via LandXML, CivilSurface.GetTrianglesSurfaces (landXMLpaht: string, onlyVisible: bool = true):Surface "
However, I still get results from the script (see fig. 1 and fig. 3).
Anyone an idea how I can get rid of the last warning?
Versions
Revit = 20.2.0.48
Dynamo Core = 2.3.0.5885
Dynamo Revit = 2.3.0.6270
Fig. 1
Fig. 2
Fig. 3
Thanks in advane.
Source data:
BA200004.RVT.0125 OT Terrein.rvt (3.0 MB)
RVT2020.2.0_D4R_CivilConnection_TINSurfaceToTopography_LandXMLTriangles_02.dyn (47.0 KB)
BA200004.DWG.0124 OT Terrein.dwg (1.3 MB)
It works just fine
that is the usual warning for the geometry working range. Use the Function.Apply to get rid of the warning
@Paolo_Emilio_Serra1
It seems something is going wrong because I’m using both Civil Connection for RVT2020 and RVT2021. In the example below I use:
Revit = 20.2.0.48
Fig. 1
Fig. 2
Do you also have a solution for this?
Thanks in advance.
Yes, the solution is that you read the documentation of CivilConnection.
Hi Paolo,
Do you also have a screenshot of the bigger picture? It is not entirely clear to me where to place the “Function Apply” node correctly.
I can also indictate that rereading the documentation was enlightening (thanks for the tip).
Thanks in advance.
