CivilConnection2021 5.0.1 - test fails
I did a test with “D4R_CivilConnection_TINSurfaceToTopography_LandXMLTriangle” in Revit version 2021.1 and have an error (see fig. 1).
Could this be due to CivilConnection2021 version 5.0.1?
Because in the past I did’t have problems in Revit 2020.2 .
Fig. 1
Fig. 2 = C:\Users\j.boonen\AppData\Roaming\Dynamo\Dynamo Revit\2.6\packages
Fig. 3
Fig. 3 = version Dynamo
Fig. 4 = should I do something with “CivilPython” ?
D4R_CivilConnection_TINSurfaceToTopography_LandXMLTriangles_02_RVT2021.1.dyn (44.8 KB)
Dynamo file
Thanks in advance.
@jacob.small
In Revit 2020.2 we only got 1 error and the surface is visible in Revit.
Maybe this is because it is a rather weird surface (see fig. 2 and fig. 3).
Fig.1 = error
Fig. 2 = surface in Revit 2020.2
Fig. 3 = surface in C3D
Script:
D4R_CivilConnection_TINSurfaceToTopography_LandXMLTriangles_02.dyn (46.8 KB)
Now get it in order for Revit 2021.1!
Hello @j.boonen,
here is a script update D4R_CivilConnection_2021_TINSurfaceToTopography_LandXMLTriangles_04.dyn (46.4 KB), where you can select surface by name. Here is video from testing https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/eba2f351-989e-4a43-af44-07760234f3e4.html
@Drbohlav
Thanks!
I’ll test it next week and let me know if it goes well!
About this warning you can read in documentation.
_CC2021
Documentation, page 30:
“Set the geometry working range to Medium and ignore the warnings associated to these settings during execution”
@Drbohlav
I just ran a test with the script “D4R_CivilConnection_2021_TINSurfaceToTopography_LandXMLTriangles_04” in RVT2021
I should get rid of the warning by following the solution in the post “CivilConnection2021 5.0.1 - test fails” (see fig. 2 and fig. 3).
However, it seems that I cannot see the triangles in Revit (terrain model ; see fig. 1)?
Fig. 1
Fig. 2
Fig. 3
Source data:
RVT2021.1.1_D4R_CivilConnection_2021_TINSurfaceToTopography_LandXMLTriangles_04.dyn (47.0 KB)
BA200004.RVT.0127 OT Terrein_RVT2021.rvt (3.3 MB)
BA200004.DWG.0126 OT Terrein_C3D2021.dwg (1.3 MB)
Do you have a solution for that?
Thanks in advance.
Hello @j.boonen, try this:
Výstřižek
@Drbohlav
Unfortunately this is not the solution (see fig. 1).
After “running” the script again it goes completely wrong (see also screencast).
Fig. 1
See also screencast
