Hello Everyone, I think this seems to be a silly question but when I try to create a Revit Family (Shape from Corridor) by using Mass.ByShapeCreaseStations it is generating zigzag object in revit. I know that I am doing something wrong but can not find it where. Please correct me if anyone knows about this. Thank you in advance!
Did you leave the geometry scaling on Medium?
Yes it is on Medium.
hmmm… not sure then. Might want to log an issue to the github for CivilConnection.
Another thing to do is check for larger coordinates in Revit. object.BoundingBox for every element should return no min or max point with a length more than 22 miles (closer still is better).
Than You @jacob.small, I will check this. But please if you found anything around of it let us know. I stuck because of this issue.
interesting!
What happens if you change the freq of your corridor from the default (I think its set to 25) to something like 5 for both the tangent and curved sections before you send the info to revit?
Okay, I will try this!
