Civil3d Solids- dynamo-Revit
It’s also possible to use the Data.Remember node in Refinery to port stuff from Dynamo for X into Dynamo for Y and back again.
  1. Open in Dynamo for X, collect the geometry and data which you want, and wire them into Remember nodes (group and label so you know what you are after).
  2. Open in Dynamo for Y, run the graph and then start to push the data into new or existing objects in your target file.
