Civil 3D Tin Volume Surface Color Range
Reviving this old thread here. What node is plugging into the Python node? Can anyone post a screenshot of their full node tree that goes with this code.
All that’s going into the python node is a surface name:
Capture
Sorry, I’ve been away from the forum for a while. Work has just been too busy. Here is a txt of the code:
surface color ranges.txt (2.4 KB)
I’d like a step-by-step as well, haha… Dynamo and Python-in-Dynamo has been mostly a self-teaching process (with great help from the reference material and advice mainly from this forum). There just isn’t a lot out there with respect to Civil 3D.
As for the Python node in question, it simply needs a surface name (String) as the input. See my reply to dylanlisec below.
Ok, so I took the basic code that @jameshitt provided and switched a few things around. The biggest change was separating the color scheme for cut and fill (red and green) volumes. There are now three inputs for the user, the surface, the size of the elevation step of the color bands, and the survey precision. This allows for an element of “play” depending how accurate the surveyor is willing to say the survey is.
I also started getting into exporting the color scale of the volume surface to excel. This would allow the user to bring the excel table back to CAD to use in sheetspace exhibits as a legend. The tricky thing is, I’m not sure how to approach creating the color portion of the legend. Right now I’m using a VBA module called myRGB provided at the link here. This isn’t really that automated. In the meantime I’ll be trying to figure out how to get a table directly into the modelspace with the correct colors.
Volume Surface Color Banding.txt (4.1 KB)
Volume Surface.dyn (21.1 KB)
myRGB.txt (546 Bytes)
HI
TRY
import sys
import math
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.Colors import *
from System import Array
dataEnteringNode = IN[0]
interval = IN[1]
surveyprecision = IN[2]
cdoc = CivilApplication.ActiveDocument
editor = adoc.Editor
def set_surface_analysis(surface_name,interval,surveyprecision):
	global adoc
	global cdoc
	with adoc.LockDocument():
		with adoc.Database as db:
            	# Place your code below
				bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
				btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
				surface = None
				for oid in cdoc.GetSurfaceIds():
					obj = t.GetObject(oid, OpenMode.ForRead)
					if obj.Name == surface_name:
						surface = obj
						break
				if surface is None:
					return False
				gp = surface.GetGeneralProperties()
				minel = gp.MinimumElevation
				maxel = gp.MaximumElevation
				#minelf = minel - (minel - (math.floor(minel / interval) * interval))
				minelf = int(minel)
				maxelc = int(maxel)
				#maxelc = ((math.ceil(maxel / interval) * interval) - maxel) + maxel
				minelfn = int(minelf)
				maxelcn = int(maxelc)
				upperprecision = 0 + surveyprecision
				lowerprecision = 0 - surveyprecision
				saed = []
				#interval = .5
				redsteps = int(((lowerprecision - minelf) / interval)+1)
				greensteps = int(((maxelc - upperprecision) / interval)+1)
				i = 0
				n = 0
				upperbound = 0
				lowerbound = 0
				table = []
				while upperbound >= minelf:
						lowerbound = lowerprecision - interval - i
						upperbound = lowerbound+interval
						g = ((250/redsteps)*n)
						b = ((250/redsteps)*n)
						saed.append(SurfaceAnalysisElevationData(lowerbound, upperbound, Color.FromRgb(250,g,b)))
						i += interval
						n += 1
						table.append([int(lowerbound),int(upperbound),250,g,b])
					i = 0
					n = 0
					while lowerbound <= maxelc:
						lowerbound = upperprecision + i
						upperbound = lowerbound + interval
						r = ((250/greensteps)*n)
						b = ((250/greensteps)*n)
						saed.append(SurfaceAnalysisElevationData(lowerbound, upperbound, Color.FromRgb(r,250,b)))
						i += interval
						n += 1
						table.append([int(lowerbound),int(upperbound),r,250,b])
				saed.append(SurfaceAnalysisElevationData(lowerprecision, 0, Color.FromRgb(255,190,92)))
				table.append([int(lowerprecision),0,255,190,92])
				saed.append(SurfaceAnalysisElevationData(0, upperprecision, Color.FromRgb(236,247,29)))
				table.append([0,int(upperprecision),263,247,29])
				sorttable = table.sort()
				surface.Analysis.SetElevationData(Array[SurfaceAnalysisElevationData](saed))
            	# Commit before end transaction
				t.Commit()
	return table
OUT = set_surface_analysis(IN[0],IN[1],IN[2])
FOR EXPORT TO EXCEL SEE THIS IS
I am new to python and how to apply this code to the surface.
Is there an updated version of this code that works in the new 2024 Dynamo/CPython3 ?
Sorry, there is no update ALL
CAN YOU Continuation By code conversion
import sys
import math
interval = IN[1]
        global adoc
        global cdoc
        outputD = {}
        output = []
                                 btrID = bt.get_Item("*Model_Space")
                                 btr = t.GetObject(btrID, OpenMode.ForWrite)
                                 #sampleLineId = sampleLines[0].InternalObjectId
                                 #obj = t.GetObject(sampleLineId, OpenMode.ForWrite)
                                 surface = None
                                        surface = obj
                                        break
                                 if surface is None:
                                    return False
                                 output.append([minel , maxel ])
                                 t.Commit()
        return output
Thank You for sending this. I see that your code states the minimum and maximum value for a volume surface. I am seeking to set the elevation ranges in the Surface Properties > Analysis Tab and then set those ranges to particular RGB color values. Do you know of any ways I could modify the code you provided to accomplish this?
use Visual Studio Code
00
I noticed in the Civil 3D API documentation they have a class called:
SurfaceAnalysisElevationData.Scheme Property
Gets or sets the color value for the elevation range. This is an AutoCAD Color object.
With an example in C#:
public Color Scheme { get; set; }
How would we convert this to code in the Python node in Dynamo?
I didn’t understand you well
Can you explain more? What you want to do
In Civil 3D, surfaces can display elevations as colors. If you right click on a surface and select “Surface Properties” > Analysis Tab > Elevations you can find the elevations as shown in the included image. Instead of adjusting these colors using the surface properties graphical user interface window, I want to use a Python node in Dynamo to adjust these color values. I was hoping to use the SurfaceAnalysisElevationData.Scheme Property from the Civil 3D 2024 API. Found here:
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=41b4d8dc-3aa3-b45a-b8fa-da0593621c6a
My question is:
What is the correct way to implement the API property (explained at the link above) into a Dynamo Python node?
Or in other words:
What is the correct Python code to adjust a Civil 3D surface color range using the API?
like this , but it is not change color range I do not know the reason
I use the Camber Surface.ElevationAnalysis node, works like a charm.
This accomplishes what I need. Thanks!
Thank You! This provides me with an option to accomplish what I need.
:white_check_mark: Checked:
:wrench: Improved Python Script for Dynamo – Get Min/Max Elevation from Multiple Surfaces :rocket:
:pushpin: Versión en Inglés
I’ve modified the script to directly accept TinSurface objects in Civil 3D 2026, allowing it to read the minimum and maximum elevations from two surfaces. The logic can be easily expanded to support a list of surfaces.
Feel free to reach out with any feedback or questions!
:pushpin: Versión en Español
He adaptado el script para que reconozca directamente dos superficies (objetos TinSurface) en Civil 3D 2026 y obtenga automáticamente las elevaciones mínima y máxima de esos objetos. Aunque en este caso son dos, puede ampliarse fácilmente para aceptar una lista completa de superficies.
Quedo atento a cualquier comentario o duda.
:backhand_index_pointing_right: :link: Mi LinkedIn : https://www.linkedin.com/in/brian-mendoza-márquez-95976a227/
import sys
import math
list_surface_obj = [IN[0], IN[1]]  # Ahora IN[0] es la lista de objetos Surface directamente
surveyprecision = 1
def get_surface_elevations(list_surface_obj, surveyprecision):
    Obtiene la elevación mínima y máxima de una superficie dada.
    :param surface_obj: Objeto de superficie de Civil 3D
    :return: Lista con [min_elev, max_elev]
    try:
                    list_surfaces = []
                    # Abrir los objetos de superficies
                    for surface_obj in list_surface_obj:
                        surface = t.GetObject(surface_obj.InternalObjectId, OpenMode.ForRead)
                        list_surfaces.append(surface)
                    list_elevations = []
                    for surface in list_surfaces:
                        # Obtener propiedades generales
                        minel = round(gp.MinimumElevation, surveyprecision)
                        maxel = round(gp.MaximumElevation, surveyprecision)
                        list_elevations.append(minel)
                        list_elevations.append(maxel)
                    t.Commit()
                    return {"max_elevation": max(list_elevations),"min_elevation": min(list_elevations) }
    except Exception as ex:
        return ["Error: " + str(ex)]
# Llamada a la función
OUT = get_surface_elevations(list_surface_obj, surveyprecision)
@jbrianmdz this doesn’t solve the user’s original issue of setting the color range of the volume surface.
