Civil3D Surface Analysis Slopes
Hi Everyone, I don’t find myself posting a lot here but could not find anything on the Surface Analysis other than the Elevations, so here goes…
I often have to evaluate designs in terms of slopes and slope arrows. The variations of criteria (for roads up to 10% but for earthworks up to 100% or sometimes simple above and under certain slopes makes me enter the properties and band a lot. I used the method ImportElevations/ExportElevations and I took the basics from this post:
Attached the dyn file, it is player ready (I think… even capturing a few errors)
NBI_SurfaceAnalysisSetSlope.dyn (32.5 KB)
Changed it a little bit to handle the output file only on Export and added slope Arrows. Also decorated it a bit (version and stuff).
NBI_SurfaceAnalysisSetSlope.dyn (37.2 KB)
Another small inconvenience for this method is that any table will not update until you hit the OK button in the Surface properties window. Somehow apparently the update of a dynamic table is arranged within the Surface properties command. Just so you know, other than that it all works great
