Hi everyone,
Has anyone encountered this error? if yes do you know how to fix it?
“Warning: Data.ImportExcel operation failed.
Creating an instance of the COM component with CLSID {00024500-0000-0000-C000-000000000046} from the IClassFactory failed due to the following error: 80010108 The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED)).”
try to re install office 365 or repair it . it should be good
Tried it… but still getting the same error… Even tried to uninstall re install the Civil 3D software… still same error.
I worked around this problem by using ExcelReader lib., otherwise you can import CSV data instead.
Instead, you can type the following code in PythonScript to do exactly the same thing.
IN[0] = file_path(string)
IN[1] = sheet_name(string)
------------------------Code-----------------------------------
import openpyxl
file_path = IN[0]
sheet_name = IN[1]
wb = openpyxl.load_workbook(file_path, data_only = False)
ws = wb[sheet_name]
result =
for i in range(ws.max_row):
row_values =
for j in range(ws.max_column):
row_values.append(
ws.cell(row=i+1, column=j+1).value
result.append(row_values)
OUT = result
