Checking Revit File Size with Dynamo
Hello is there a way where I can check the Revit file size with dynamo?
I tried something like this but doesn’t give me the proper answer
Thank you!
Hi @mixology,
You can use the Documents Properties node.
im trying to limit myself from using too many packages (im already using 4 for my current script) - is there a way to do it without inviting genius loci? possibly just with default dynamo nodes?
thanks!
Sorry for another question - What does ‘Mo’ stand for?
This may be possible with many nodes.
I will correct it. It’s MB in french (megabyte = megaoctet )
Thank you for clarification!
Hey another question,
I need to check not just the file size of the document, but dynamo to show a warning if the file size exceeds a certain limit in the script? is there a way to get that?
