I want to set a check on the work plane-based of a family property in Dynamo.
I checked the parameter in the Elements.Parameters node of Dynamo and there is no parameter called work plane-based.
I would like to know if there is a way to change such a parameter in Dynamo.
Environment
Revit: 2019.2.1.1
Dynamo: 1.3.4.6666
sovitek
February 16, 2023, 9:39am
2
Hello @katsumi1.fukuda …could something work ?
Thank you very much for the information.
In which package are “FamilyDocument SubCategory”, “All Families Of Category” and “SetParameterByName in Document” included respectively?
sovitek
February 17, 2023, 5:01am
4
Hi these is from Genius loci and clockwork it was just if you wanna background open…if not you can use ootb…
Sorry, “Element Classes” and “All Element of Class” were not found in OOTB for Revit 2019 and 2022.
Also, are you running the program in the image above with the family file open?
sovitek
February 17, 2023, 5:34am
6
It has just changed name in 23 try with element types – all element of types…
I was able to change it the way you showed me!
Thank you so much!
