Hey,
i try do get a Excel Sheet of a Parameter to check, if the Paramter is filled out on specific Revit-Familys is my Model. I tried to build this Skripts but it doesn’t work.
Someone can help me
Hey,
Someone can help me
can you post the graph again with all previews enabled?
there is no error message in Dynamo when the skript runs, but the Excel table is wrong and does not contain the desired parameters.
Hi matthias,
I have duplicated your script with different parameters and it works as expected. I would just put a watch node between on the transposed data and check what information you are actually feeding into excel.
