@jacob.small
Thanks.
I’m afraid I still don’t understand what you mean. My Dynamo language is unfortunately not enough.
I want the “Family Types” which I have duplicated as shown above. I don’t want to select the duplicated Family Types Node manually but filter them automatically with a filter or the String.Contains Node. So basically just replace the Family Types Node with a list which I can then search.
Best you send me a short and simple workflow. I don’t know Dynamo that well and many technical terms don’t mean anything to me.
And also important: I want to get all family types which are available and not just the once which are placed. In my example The window with the dimensions 2000,000000 x 1500,000000 are not placed. Thats why the window is noct in the List after “All Family Types Of Category”
This is not the case. The node retrieves all family types, even the ones which don’t have any FamilyInstances. You are not getting any matches since:
You are trying to match 2000,000000 x 1500,000000 against probably 2000 x 1500, so that will never return a match.
You are only matching the first 2 items of the list using the == node, use cross-lacing with List.AnyTrue afterwards or use List.Contains with the item set to @L1.
