Changing System Families
Guys,
I need to change one system family to another, is this possible?
I have a pipe system drawn in copper but I need to change it to steel. I can do this for the fittings by swapping out the families but can’t seem to change the pipe as its a system family.
Any idea’s
Thanks for any help in advance
You can change a system family by changing its System Type with SetParameterByName. The parameter value is the new piping system type.
Like this:
Hi guys,
Thanks for all your help, it’s much appreciated and this works great but what I would like to do is something similar to the sketch below.
I need to be able to fix the types by name as I will be using this graph in multiple projects that may have more or less pipe systems in them. Is this possible?
I hope I’m making sense.
Thanks again
Do you want to search for a pipe type by name and then replace it with another pipe type by name?
Yes that’s the goal, but I would like to use a name as opposed to a number from a list as lists may vary from project to project.
Thanks.
Guys, found my answer here in another thread answered by Kulkul
Thanks for all your help!
Cheers
Paul.
