Set The wall thickness or create a wall by thickness
I’m new to Dynamo, can Dynamo create walls by thickness? ! Thank you very much! (English is not my native language)
hi and welcome,
I don’t quite understand your question. thickness of what?
try to look at “wall.byCurveAndHeight” here you select a wall type with a defined thickness
I was able to get the midline of the two-wire wall, and I was going to put the wall in the right place depending on the thickness of the wall. That’s what I wanted to do, but the need for the different thickness of the wall was the key. Could this be done in Dynamo?
My problem has been solved, it can work perfectly
