All,
I am having a strange issue with a script I built yesterday. The goal of the script it to grab all objects of certain categories and swap them to the Existing phase. It also spits out a count of all objects as well as a count of the objects that needed to be swapped.
When run, it correctly filters out the objects that need to be swapped but it only swaps a single element each pass. Can anyone spot why that would be? Below is a picture and file of the script in question. Below it is a simplified script that is working, it just doesn’t filter out objects that dont need to be swapped.
ChangeElementsToExisting.dyn (17.8 KB)
