Changing Model In Place Family Category Using Dynamo
Hello Everyone can we Change Model In Place Families Category Using Dynamo ??/
No. There is no way to programmatically modify an in-place model as access to in-place model commands is not exposed in the Revit API so therefore Dynamo also has no access. The best you could do is programmatically swap the in-place family instance with a loadable family with matching geometry. Such a tool would be a big lift to create though.
Okay, Thanks.
May be try like this?
Im almost certain that there is a public extension for pyRevit where someone has done this already for freeeeee.
I cant remember the extention name thiugh… :frowning:
I have written this in Python as well; it’s not an easy task for complex models if you want to maintain editable geometry, materials, parameters and the like. Easier if you just want to move geometry.
Hi so i did find this today.
It is part of the pyChilizer extension in pyRevit.
