hi, i need to put in many view of elevations and sections only the trees on realistic mode through dynamo.
i’m been working on a script but it seems not working.
If I am understanding your question correctly, you will not be able to do what you want- that’s not how Revit works. “Realistic” (like Wireframe, Hidden Line, Shaded, etc.) is a property of the view. It cannot be overridden by category.
Looking at your script, it appears that you are trying to set a parameter of the element. If there is some parameter in the family that controls geometry visibility, maybe you can share the family.
Joe
Hello @bianca.innocentinTR4 and welcome to the forum, yes as @Joe.Charpentier point out these setting is for entire view…and can be set as here
thanks for the tips but when i try to serch in dynamo document.activeview or display styles i do not find them… are there specific packages for them?
Yes…you can probably use OOTB nodes depends on which version you are in…i just like use active view from spring as it have option for refresh
Is it a viewtemplate ?
nope… is on none…that’ weird… it should be working right?
no worries
no not sure then, do you have a small sample rvt you could share with this issue ?
if you cant share here, then upload the sample to webtrnsfer, filetransfer etc…and share the link here
here the model with the family that i want to change in realistic mode, and the script.
cheers take a look later…does it work if you set manuelly ?
edit have tried here in english version works great…
Do you have frence names for , realistic, shaded etc ?
thanks a lot
. I thought it would be easier… yep i tried manually and also in differents views(3d included)… but it seems not working
Might be a localization issue.
Try launching Revit in english and see if that fixes things.
yes thats how visuel styles work…but great we find the issue, please mark Jacobs solution ![]()
PS you could try these nodes from archilab as well and sse it works in french version
but not sure
ok but the reason to make the dynamo script was to make only the plants appear in realistic mode, like a filter…
not possible as far i know…but probably there could be a hack…but i dont know that as it very rare i do that stuff…probably insert as an image so…
That’s not how Revit works. A view is either “Realistic” or it is not. You cannot make that choice on a category-by-category basis.
Rule of thumb: If you can’t do it using the Revit User Interface (i.e. right in Revit) you almost certainly can’t do it via Dynamo.
