Hi all,
In dynamo is it possible to change all the plumbing family host from" floor "to "level "? For instance in this case, change it from floor: mgs_vynyl_apts to level: Level 3.
Thanks.
Hi all,
Thanks.
I would imagine you could only do this under certain circumstances.
The family itself will be a Floor Hosted family, meaning it hosts to floors, not levels. And that parameter is a read only parameter (i think).
If they are not floor hosted, you may be able to use Dynamo to group/select all the elements and you can just use the “Pick New Host” button inside Revit and (in an elevation/section view) select the level you want them to be hosted to.
It may be able to be done via DS or Python. I will leave that to the Guru’s.
Hi Alisder,
Thanks for your kindly reply. yet I think it’s read only parameter.
regards,
Dylan
Hi @dylanpeng ,
I have found this way but it has to make a copy of regular element . After that , you can remove last element .
regards,
