Our Team has drawn Ductworks on the Wrong Workset. I changed the Workset, but Insulation Elements are still on the same Workset and can seem to change them from properties as it is greyed out. Does anyone have any workaround for this?
you need to relinquish first
Just Tried that and it doesn’t work. I don’t think it’s ownership issue.
i dont think you can change the workset of an insulation because it is owned by an element. What you can do is retrieve all existing data of the existing insulation, delete it, and create new one with the existing data you retrieved.
Thanks, @stillgotme . I was hoping for a solution where I don’t have to redo all the Annotations again.
@Sujan well i think you can try this workaround. It seems that dynamo isnt required for this case?
or if you want to mass do it, just use that methodology with dynamo
