Hello Everybody, Hope you are all fine.
I’m a new user to Dynamo, but after some classes i think it is already time to try to run my first program.
So i have a family Called “Diagrama Unifilar” inside my Revit project. It contais an array parameter called “Numero de Circuitos”
I wish to set the value of this parameter to be the same as the number of circuits in my project.
I think i did everything ok, but i keep getting an error message called: “Warning: No function called SetParameterByName on a Revit.Elements.Parameter that takes __array,string,string could be found”
